Adding a 7th axis
  • Hello, I'm am finally back in the country (working on Movies in Mexico and Canada) and I'm going to try and get my 7th axis up and going again.
    I have a Fanuc R-2000iB-100P # F-89786
    Fanuc System Controller R-30iA
    Aux Servo Card ai SV A06B-6117-H106
    AC Servo Motor ai SR 30/3000 A06B-0041-B605#S042
    I have the following cables installed
    Link TB1 on the Aux Drive to CRR68 on the 6-axis drive
    Battery Connector CX5X A06B-6093-K303
    CXA2B on the Aux Drive to CXA2A on the 6-axis Drive A06B-6110-K210
    COP10B on the Aux Drive to COP10A on the 6-axis Drive Optical connector
    ENC1/JF1 Pulse coder L axis to Servo Motor A06B-6078-K225
    CZ2 Motor Power L axis to Servo Motor
    CRR65 on the 6-axis Drive to the Servo Motor
    There is also a cable for the fan on the Motor, not sure where to connect this.
    If you have any knowledge on how to add the Aux drive to the system I would greatly
    appreciate it if you could give me some guidance on how to proceed.
    Thanks,
    Michael Kirchmeier
  • I'm not sure if this is exactly what you are asking but go into a controlled start, and then into variables and down to click on $SCR and change $NUM_GROUP to 2 and $NUM_TOT_AXS to 7. And then go back and go into $SCR_GRP<$SCR_GRP{2} (MAY NEED TO RESTART TO GET IT TO SHOW UP) set number of axes to 1 and then $SCR_GRP{2}. $AXISORDER set the first axis to 7. Then while still under controlled start go to menu<maintenance and set up the grp 2 axis as what you want (basic positioner, etc). you can either hit the soft key for auto setup or manual and enter all the motor info stuff yourself
