Passing arguments to called program in Karel
  • TitusLepic
  • December 12, 2019 at 11:06 PM
  • TitusLepic
    112
    442
    I'm trying to display a yes/no menu from Karel. From TP, it would look like this:
    CALL MHPRMPTY(2,37)
    I can call MHPRMPTY from Karel using CALL_PROG but I can't figure out how to pass the arguments and I can't find anything about it in the karel reference manual. Any help would be appreciated. Thanks.
  • jay
    25
    82
    • December 13, 2019 at 12:39 AM
    As far as I know there is no way to pass TPE arguments from KAREL. Maybe there is a secret builtin for that.
    You could write a simple wrapper that uses registers e.g.
    MHPRMPTY_WRAPPER.TP:
    CALL MHPRMPTY(R[x],R[y]) ;
    Then just set R[x] and R[y] from KAREL before using CALL_PROG.
    ONE Robotics Company
  • MIRobotGuy
    8
    34
    • December 18, 2019 at 12:25 PM
    This will work. I have used this in the past.
    PROGRAM TPP_ARG
    %COMMENT = 'TPP Arg to Karel'
    VAR
      arg : INTEGER
      -- Dummy Variables for Karel Built-Ins
      Dummy_Int : INTEGER
      Dummy_Rel : REAL
      Dummy_Str : STRING[10]
      STATUS : INTEGER
    ---                          Main Program                              ---
    BEGIN
    -- Use the Get-Parameter Built-In to read the TPP Arguement
    --          |-- Parameter Number (Arguement Number)
    --          |  |-- Data Type (1-INTEGER, 2-REAL, 3-STRING)
    --          |  |   |-- value of the parameter if the data_type is INTEGER
    --          |  |   |       |-- value of the parameter if the data_type is REAL
    --          |  |   |       |          |-- value of the parameter if the data_type is STRING
    --          V  V   V       V          V        V-- return status
    GET_TPE_PRM(1, 1, arg, Dummy_Rel, Dummy_Str, STATUS)
    -- Display Arguement Value on the Teach Pendant
    WRITE('value of arguement:', arg, CR)
    END TPP_ARG
    MI Robot Guy
  • Bill Lin
    8
    • December 27, 2019 at 3:40 PM
    Quote from MIRobotGuy
    PROGRAM TPP_ARG
    VAR
      arg : INTEGER
      Dummy_Int : INTEGER
      Dummy_Rel : REAL
      STATUS : INTEGER
    BEGIN
    END TPP_ARG
    that' great!:smiling_face:
  • rankingofficer
    8
    • October 21, 2021 at 11:24 AM
    Below I show you how to pass arguments from Karel to Karel, not sure if you can pass arguments from Karel to TP.
    In Karel you cannot pass arguments from one Karel program to another Karel program exactly like you do in a TP program eg CALL GET_AREA(2,5);
    The answer is to use the ROUTINE function. This function is surprisingly well explained in the Karel reference manual.
    The examples below show the basic concept:
    Program MATH_LIB
    ROUTINE GET_AREA(length: REAL; width: REAL; area: REAL)
    BEGIN
    area = length * width
    END GET_AREA
    BEGIN
    --Main body of program.
    -- Can be empty
    END MATH_LIB
    Program TEST
    VAR
    area: REAL
    --declare the routine like it is a variable
    ROUTINE GET_AREA(length: REAL; width: REAL; area: REAL) FROM MATH_LIB
    BEGIN
    GET_AREA(2,2,area) -- pass 'area' by reference
    WRITE(’Area = ’, area, CR) -- Print: Area = 4
    END TEST
    Note you can also make the ROUTINE return a value, instead of passing a variable by reference. eg.
    ROUTINE GET_AREA(length: REAL; width: REAL) : REAL
    VAR area: REAL
    BEGIN
    RETURN (area)
    RETURN (length * width) -- Maybe this works too
    END GET_AREA
    Program TEST2
    VAR
    area: REAL
    ROUTINE GET_AREA(length: REAL; width: REAL) : REAL FROM MATH_LIB
    BEGIN
    area = GET_AREA(2,2) -- Returns a number
    END TEST2
