hello dears
today when i turn the robot on, its freez in initializing robot interface.
controller is KR C4.
Robot is KR 120 R2900.
and some information in picture.
how can i fix it?
whats the problem?
Best Regards,
hello dears
how can i fix it?
whats the problem?
Best Regards,
Today when I tried to save my marriage it did not work.
how can i fix it?
whats the problem?
Best Regards,
Seriously with this much information nobody will be able to help you. Consider at least the read me first advices.
Fubini
Fubini
is it ok now?
Well still not much info:
What is the history of the machine? What where the last modifications?
Have you tried to unplug the Smartpad and plugged in again? What do you see when you connect a monitor directly to the controller? What have you already done yourself to find the problem? Have you tried switching the mode op key? ...
And think about resizing those images as mentioned in the read first.
Fubini
Fubini
it was working very well. today when i wanted to start it in automatic mode it dose not work.
i turn it off and turn it on again and after that i have this problem.
yes i unplugged and plugged smart pad but still i have that problem.
i change mode op key to T1 and restart robot but nothing. and also i checked it in T2 and auto and EXT mod.
when ever i changed mode i restart robot.
and also i deselected robot and select it again and nothing change.
do you have any other suggestion?
i don't have a monitor with DVI cable today. i have to prepare for tomorrow.
i will check and tell you.
Hello dears
There is not another idea?
Is this type of problem for hardware or software?
Its so important for me.
I would bet since everything is green, on boot, turn the mode selector key, turn it back wait a few seconds and it will load. It has happened on KSS 8.3.32.
i connected a monitor and it solved.
What was the problem, how was it solved?
i disconnected all of the KRC computer cable and connect it again.
