Hello everyone
Simple question, what is and where is the limitswitch on the emergency circuit ? Physicaly on the robot. If you have picture it would be even better !!
Thank you
Hello everyone
Thank you
Limit switches are optional, they are typically used on Axis 1, 2 or 3, or a combination. They go where you wherever you choose to put them. Used in conjunction with a ring upon which the roller of the switch rides. You would move and/or cut the ring as required to limit the robot motion, stopping it if it comes off the switch.
Can't get much more specific without knowing the robot and controller make & model.
Yes my robot is IRB1400H S4C M2000.
My question is about LIM1 and LIM2 always at 0 state in the controller. I have find jumper in the XP18 connector to make loop to close 361-369 and 362-370.
Therefore no external hardware on the robot. The connector (DSQC509) X1 3-4 and X2 3-4 are jumped.
I don't understand why the LIM1 and LIM2 are always at 0 state ?
Because the switches that are not present are, of course, off.
No external switch all cable are jumped.
Why the LIM1 and LIM2 are 0 state ? He should be in 1 ?
Great job with the pics.
Need to jumper the external axis limit switches if they're not being used.
Panel Unit X1:11-to-12 and X2:11-to-12
If you follow along in the M2000 controller circuit diagrams, it's page 4-1, location C:2.
Thank you !!!
My fault I used as reference my manual of M97A...
