Has anyone sucessfully integrated at Mori Lathe to a fanuc robot using the mori as a scanner and the fanuc robot as an AB adapter?
Fanuc robot to Mori lathe
kab3472 -
September 27, 2019 at 4:00 PM -
what is an AB adapter? Do you mean an Ethernet I/P adapter?
Yes. I meant with Allen Bradley ethernet IP adapter option
If the Mori is a Fanuc control, it should be fairly straight forward. We integrate other machine tool system with EIP quite frequently. However, we'll set the machine up as a slave/adapter and robot as scanner. Perspective I guess.
We actually just got it figured out. For some reason we have no values coming from mori but that is a whole separate issue.
