Using EthernetKRL for Realtime Communication
  • ROBO_APE
  • August 22, 2019 at 11:49 PM
  • ROBO_APE
    System Specs:
    KRC4 Controller with KR 6 R700 sixx manipulator
    WV5.0 build V5.0.9
    EthernetKRL V2.2.8.155
    I am currently trying to utilize EthernetKRL as a real-time interface to communicate my robot's position back to my external system. I am able to run my program in the submit interpreter for about 5 seconds before I get that my ethernet connection has been disconnected. I was hoping that the issue was just a memory error but it seems as though I am clearing my buffer.
    Error: EKI00010
    Ethernet is Disconnected.
    Any ideas or advice is much needed.
    Files
    KRL.zip 1.15 kB – 44 Downloads
    panic mode
    1,268
    13,041
    • August 23, 2019 at 4:28 AM
    that configuration is rather strange. i
    when EKI runs as server, then no client side settings are to be specified in config.
    also EKI is not a real time interface. that would be RSI.
    connection is created and closed by client, not server.
    looks like you are working on both client and server simultaneously. it is easier to battle one thing at a time.
    i would suggest starting with sample program that KUKA provides and do not change it until you get client side working.
    once you get smooth communication, then add more tags etc.
  • EKI
  • EthernetKRL
