I want to ream out a hole. The hole is at a slight angle to the world. The hole will float in the Z direction to the tool frame. The robot is programmed to approach the hole parallel until a probe touches the hole surface. Then I want the robot to move from the probe touch in Z negative by a specific distance into the hole. I know it's a position register programming but I dont have the experience to do it.
Help moving incremental in Z after probe touch
krsholl -
August 6, 2019 at 4:34 PM -
After the touch probe makes contact.
PR x=LPOS
PR x,3 = PR x,3 - (amount you want to move)
PR x is whichever PR you want to use.
I'm not sure if you're talking about tool Z or user Z. If it's user Z, stare284's method will work. If you're talking about tool Z though, use a tool offset
PR[1] = LPOS -- stores start position (when probe makes contact)
PR[2] = LPOS -- make sure that your offset PR is set to cartesian
PR[2] = PR[2] - PR[2] -- zero out your offset PR
PR[2,3] = {z offset} -- normally your tool Z is positive in the direction your tool is pointing
PR[1] 100mm/sec FINE Tool_Offset, PR[2]
Thank you. So the probe is going to set an input. How do I tie the input into PR x=LPOS so that the robot stops its approach prior to the input to the PR set distance?
Use the skip condition. You can search this board for more details, but it will look something like this:
SKIP CONDITION RI[1]=ON --in this example, the robot is looking for RI[1] to turn on
L PR[3] 100mm/sec FINE Skip,LBL[1] --move to PR[3] while looking for RI[1] to turn on. If RI[1] comes on before it gets to PR[3], motion stops and the robot goes to the next line. If it makes it to PR[3] without RI[1] coming on, the program jumps to LBL[1]
LBL[1]
--Code to handle sensor not turning on
Thanks for taking the time to type out this example. A big help.
