Is there anyway to recover a cell in motosim when you get a controller error? It will not let me open the cell and since it took over a week to get done I was hoping for a miracle.
Motosim
Noob1982 -
August 6, 2019 at 3:19 PM -
Don't know what version you are using. I've had this and been able to reboot the virtual controller and eventually work sometimes. There may be in the cell's folder a VRC.BIN.bak file. I would make a complete copy of the cell's folder, just in case. In the pdf that is included at install there is a section that describes how to recover. It is back in the FAQ section.
In 2018 there is a Backup function that may restore the cell. Under the robot icon in the upper left. Option, Option Setting, Backup. There may be some zip files that could be used to restore the cell.
The issue is the cell will not boot up at all. I have no access to the cell because it faults out before it loads. I can't reboot the controller because it never loads.
Try one of the other two methods then, if available. VRC.BIN.bak file or restore the cell, if available.
