Halo I get a error 5000 saying robot cannot move to desired point the point has to be modified. That is after tcp change on a s4c+. I go to the jogging window and put in world, tool0 and workob0. The data, then tool data and highlight the too then define and method : tcp orient not set modpos the 4 points then ok get the value of the knew tool and push ok. When I want to home the robot it says cannot move to desired position. Modify position in program. Does someone know why I get this error. Thank you
Error after tcp change
Firsteverything -
August 2, 2019 at 4:11 PM -
So you taught Home first and then defined the TCP? You first need a defined TCP, then teach positions.
No we have a existing robot with home position and +- 170 modules then we moved the robot to another machine where the ronot runs 100%. But we changed the angle and position of the the tool so that you dot get a singularity error. Now when we redo the move l points an you working with tool in your jogging window insted of the tool moving straight to your work it moves in another direction.
Is there a way I can manually measure the tcp from the base of the robot and enter the values manually.
The TCP does not originate at the base, it originates at the faceplate, axis 6.
Post the two values (new TCP / old TCP), I'm guessing something is wrong with the orientation and not X/Y/Z
Thank you we started with the old tcp value because we couldnt wait and decided to leave it until December
