Not able to change the group masking after the program is already created...
How to change the Group masking after the program is already made
sanjay bisht -
August 1, 2019 at 10:31 PM -
Couple of ways.
[list type=decimal]
- Take the program offline, modify the group mask, and load it back in.
- On the pendant, create a program with the correct group mask setting, copy whole program from original to new, delete original, rename new to old.
[/list] -
Look up in your manual on how to do a group exchange... Otherwise...
Menu, 1 Utilities, 2 Group Exchg
Select your original program and name your new program
Under Group Selection, you'll want to copy the original group to your new group by knowing what your original group is. Line 1 will show you your groups available to the right of the program name. So if the original group is "2", go to line 4 and cursor over to New Grp [0] and change that to whatever group you want.Essentially, you're copying your original program and creating a new one through this feature. Once this is done, then delete the original and rename the new program.
Do an all of the backup prior to this in case you screw something up...
