Hello.
Tell me what line does the robot send / receive?
For example:
<Message>Example message</Message>
or
Example message
Does anyone have a source server for sharing information?
Hello.
For example:
or
Example message
This is all in the manual. EKI can send/receive either XML-formatted data, or "raw" ASCII strings, depending on how the channel file is configured.
Demo C# server program attached, as a .TXT file.
Thanks!
But in the instructions there is no answer to my question: which line is transmitted, with the node name or not?
The file that you attached I plan to use as a base.
...as I said, it sends either XML-formatted ASCII, or raw ASCII. Your channel config XML file defines the framework, and the EKI_SET commands fill in the values.
