I have a robot that used to have a linear fine movement to home before it decides which conveyor to place the part on. To save cycle time I changed that movement to CNT 100. This worked fine for some time, but with a new heavier part only (as far as I can tell) we get intermittent MOTN-110 command.
Cause: Cannot replan joint motion in interpolator for this move.
Remedy: Use FINE in last L statement.
What I can not explain to myself is why this only happens intermittently, and only (so it seems) with heavier parts. We’re talking going from 40kg to 50kg. The payload is set to 165 kg btw. Not my doing and I do not want to change parameters I do not fully understand just yet.
Any explanations and ways around it would be appreciated.
