please advise me how to simply align the robot axis flange/tool with the lathe rotation axis? To be coaxial, collinear. To be able to move the robot parallel along lathe axis.
Simple answer: teach a base in the center of your lathe rotational axis.
Complex answer: Read "read first" topic and give more information
The most accurate method is to teach a frame or coordinate system with (probably) the coordinate system Z-Axis aligned with the spindle axis. In order to do this, you can make a simple fixture to help establish coord sys location points. You will also need an accurate pointer on the flange in which to teach. See the picture for one solution schematic.
Another less accurate but possibly suitable method is by trial an error:
What about ForceTorqueControl software option? If high accuracy is required.
Thank you very much for your help. I'll try your suggestions.
