Hope you can help me with this.
I'm setting up a collaborative robot and need to use two different force settings.
- Limit1: 50N for regular moves
- Limit2: 150N for fixture moves
Those settings can be changed in DCS menu by the use of a disabling input. Basically you set two limits and use an input to disable one of them.
I’ve been reading the collaborative robot operator’s manual but it talks about using Safe I/O Connect option which I don’t have.
Is there another way to setup a disabling input for one of the limits?
I see option for SIR and other safe I/O but I’m not sure how to turn them On/Off in the program.
Thanks,
Tom
