Dear Friends,
Can anyone tell me the difference between IRB 6400 M97 and IRB 6400 M97A?
Thank you
Dear Friends,
Thank you
M97 & M97A both used RW3.0 except the M97A upgraded the Robot CPU from DSQC322 (1 ext axis) to the faster DSQC363 (6 ext axis)
M97A1 upgraded the Main CPU from the old S4 DSQC325 to the DSQC361 which allowed it to run RW3.1.
I only recall seeing the S4CPC (Tophat) on the M97A1 and newer that was running at least RW3.1.
I don't remember the changes in the IRB6400 robot if any until M98.
Hi Skooter,
Thank you.
Are Robot CPU DSQC322 and DSQC363 inter changeable assuming I am only using 1 external axis.
The DSQC363 will replace the DSQC322 without an issue and run either RW3.0 or 3.1
The DSQC322 can replace the DSQC363 if running RW3.0 and up to 1 external
