Hey, I am looking into what is the procedure to change the KSS version in OfficeLite, is there a download server where you get a new virtual machine image or do you update it like on an actual robot - if so where do you get the files from?
Additionally if we have a license which came with KSS8.3 can we use KSS8.5 for example?
OfficeLite KSS Version
dexterv -
April 25, 2019 at 10:31 AM -
Office Lite is offered with only few KSS versions pre-installed. I think OL_8.3 actually comes with KSS8.3.4.xxx.
to use different (compatible) version, one can do KSS upgrade (or downgrade). Compatible version will have first two version numbers the same (8.3 for example). moving from 8.3 to 8.5 will not work, it will require new OL.
KSS upgrade is done the same was as on real KRC4 controller:
1. make backups...
2. login as expert
3. set path where the new version is to be installed from (StatUp>Additional Software> New Software> Configure Path>Configure>Installation path for KRC update via Network; select path, save, save ...)
4. perform installation (StartUp>Software Update>Net)
5. follow the prompts and reboot when prompted.
