  4. ABB Robot Forum
Relative pose of tool0
  • JonasHS
  • April 5, 2019 at 12:26 PM
  • JonasHS
    Does anyone know how I can find and calculate the relative pose of tool0 (end effector) coordinate frame with respect to base coordinate frame on an ABB IRB120? All other relative poses are known.
    I have attached a picture of the robot. User frame and object frame should be swapped around.
    Hope it makes sense.
    Images
      • 575.45 kB
      • 1,672 × 2,904
      • 46
    Files
    IRB120.jpg_thumb 18.46 kB – 60 Downloads
    Edited once, last by JonasHS (April 5, 2019 at 12:30 PM).
    SkyeFire
    1,052
    9,429
    • April 5, 2019 at 7:10 PM
    Well, it's been a looong time since I had to do anything like this in RAPID, but if I understand you correctly, you could probably do something like PoseMult(CRobT, PoseInv(tool data))
    The idea is, you take the current position of the TCP, and multiply it by the inverse of the active tool. That should get you the position of "Tool 0", the center of the A6 flange, in the active Work Object.
  • SAABoholic
    21
    5
    550
    • April 5, 2019 at 7:38 PM
    If your World/Base is not the same, the relationship between them should be known (check your system parameters if nothing else).
    Easiest way to accomplish what you're looking to do is to convert your current position into joint target (using your active tool/wobj)
    and then convert the joint target back to a robtarget using Tool0 and a wobj with the known "negative" relationship between your Base/world. This should (in theory anyway, I haven't tested it yet) give you the robtarget in BASE using tool 0 and from there you can extract the pose (if that's all you want).
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • April 5, 2019 at 7:43 PM
    Why not just CRobT(Tool0,Wobj0) ?
  • SAABoholic
    21
    5
    550
    • April 5, 2019 at 7:53 PM
    Last I checked that would give you the coordinates relative to World.
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • April 5, 2019 at 7:59 PM
    So if the world and base are coincident, that would be sufficient. But like you said, if they are not, then perhaps more work needs to be done.
  • robotero
    14
    346
    • April 15, 2019 at 5:28 PM
    The position of the tool relative to world object is known
    And is the product of three transformations:
    Worldtobase*basetotool0*TCP
    You want to know the position tool0 relative to base
    You then need to premultiply by the inverse of Worldtobase and post multiply by the inverse of TCP
    I am sure there are commands inside RAPID to do the math
    What robot were version is installed in your robot?
    IN version 6.5 new useful mathematical functions were added
