Hello
I have two Kuka robots KR 210 L150-2 KRC2 ed 2005, with KSS 5.6.6 and 5.6.9
The one having KSS 5.6.9 it allows to change with touchup coordinates in a line code from a selected program, in T1 or T2.
The second one with KSS 5.6.6 when try same thing when press touchup message code 3 TH unknown module and do not allow to do any modification.
I read here something about softkeykuka.ini file in BASIS TECHNLOGYPACKET, I went there and compared both files from both versions, and I found that 5.6.9 has some more instructions on BASIS TECHnology, in the end.
So, I copied softkeykuka.ini from 5.6.9 to robot with 5.6.6 and tried to edit a program line with change/touchup, but same unknown module message.
Any suggestion , what could be the difference?
Thank you.
