Position variable?.
  • multani33
  • March 11, 2019 at 4:55 AM
  • multani33
    15
    What is the position variables in the DX200 whats it used for? Job ex :help:example would help
  • Lemster68
    301
    2,469
    Blog Articles
    7
    • March 11, 2019 at 1:29 PM
    Position variables are just a globally stored position. You can access them and move to them in any job. They can be stored as pulse, robot, base or user.
  • MaxG
    66
    • March 11, 2019 at 2:30 PM
    A position variable contains all the data for a position. To use a position variable in a job you must ensure that the position variable contains data. Then in the job you goto the Infom menu and select Motion key. And select motion type and the position variable address to use. The position variable can also be manipulated while a job is executing. Example... if you have a position variable 1 with Z value 100mm. In the job you can use the instruction SETE and set the Z value alue to 200mm. Maybe you want to stack something so you place the 1st part down then you use SETE and change Z to 200mm before the next part is placed down
    Edited once, last by MaxG (March 11, 2019 at 2:33 PM).
  • 95devils
    234
    8
    1,949
    • March 11, 2019 at 7:35 PM
    Position Variables can be used to:
    Move to an absolute position.
    Move to an offset from the current position (IMOV instruction).
    Shifting, both temporary and permanent. (SFTON instruction, temporary. Parallel Shift Job, Permanent)
  • ToccoEnorme
    34
    • September 26, 2024 at 12:23 PM
    Hi, I´m trying to find a list of position variables but I can´t find it.
    for example:
    P20 (1) = X for that position
    P20 (2) = Y for that position
    P20 (3) = Z for that position
    P20 (4) = rX for that position
    P20 (5) = rY for that position
    P20 (6) = rZ for that position
    What about after that? how much and what data is there?
    for example:
    P20 (7) = ?
    P20 (8) = ?
    P20 (9) = ?
  • 95devils
    234
    8
    1,949
    • September 26, 2024 at 6:23 PM
    Quote from ToccoEnorme
    for example:
    for example:
    P20 (7) = ?
    P20 (8) = ?
    P20 (9) = ?
    There isn’t anything else on a 6-axis robot. The only other is if you have a 7-axis robot. P20 (7) would be either the Theta (E) in pulse or XYZ (Re).
