mxAutomation - KRC_Initialize not cooperating
  • kae
  • February 26, 2019 at 4:58 PM
  • kae
    I apologize in advance if this topic is too elementary but I have now searched through a lot of docs, forum posts and not seen anyone with similar problem.
    I am using a KRC4 with mxAutomation set up over profinet/-safe to connect a Siemens 1516F controller. KRC4 is the device. I have configured the IO correctly and my software is set up like this.
    KRC_ReadAxisGroup
    KRC_Initialize
    <KUKA mxAutomation blocks here>
    KRC_WriteAxisGroup
    The problem is that the Initialize refuses to report "Done". I get no error feedback from the block. I have triple checked my IO addresses and they are correct. I do seem to get some information from the controller but still no init feedback. ANy special settings I have to do in the controller? Do any of you have any tips of what I have to do to get it initialized. I have looked at the Display-Inputs/Outputs-Automatic Eternal IO's and to me it seems ok. :help:
  • hiimtom
    5
    19
    • February 27, 2019 at 1:07 AM
    Are there any messages appearing on the SmartPAD ?
  • kae
    • February 27, 2019 at 9:45 AM
    General Motion Enable KSS00203. This is a command that should come from the PLC after I get the init up and running right?
    Edit: I also see that ProConOs seems to be in stop mode. Could this indicate that my controller is set up the wrong way?
    Images
      • 1.88 MB
      • 4,032 × 3,024
      • 64
    Files
    ProconOs.jpg_thumb 27.16 kB – 84 Downloads
    Edited once, last by kae (February 27, 2019 at 10:18 AM).
  • panic mode
    1,267
    13,033
    • February 27, 2019 at 2:10 PM
    it clearly says that there is an I/O configuration issue
  • kae
    • February 27, 2019 at 2:48 PM
    Yeah. The KRC4 came set up from KUKA so need to contact them then as we dont have licences to set up the config in ProConOs. Just so that I have not misunderstood anything here. To correct this I would need to reconfigure in the KRC project using the ProConOS/mxAutomation optional package or can this be done from the smartPad?
    Edited once, last by kae (February 27, 2019 at 2:51 PM).
  • panic mode
    1,267
    13,033
    • February 28, 2019 at 12:02 AM
    Without it, you will need a template project that is already configured, then import all your stuff into it (robot, programs, IO config etc.).
