Hello, I Insert this program (look at the pic please) when I start this program, the alarm shows me, position VR is Wrong, Where is the problem ?? Is it possible to insert the line PR1 = VR1???
Fanuc IR vision
Passionate -
February 25, 2019 at 8:53 PM -
what data contain in the VR[1]? What set up do you have in your iRVision tool: is it part position/fixed frame offset/tool offset.
based on this information answer will show up by itself.
the coordinates of VR1 are the coordinates of the placement of the piece or not? I calibrated the camera and took a user frame from the camera, and then I wrote my program. is this the right method?
Youss49
First. You need to be sure that the software see the part. If software doesnt see the part it will not load values on vr1
Youss49
What you selected for Offset Mode in your vision tool? Based on your select you will have or offset data or object position.
