Hi everyone,
I have a problem with connecting to the robot. IRB 1400 M98 from 1999 with S4C + controller. I want to connect using an Ethernet cable. In systemparametrs I have only defined physical sio channels, I can set ethernet, but I do not know what values to set IP and subnet mask. In addition, what will be the gateway address? Earlier (with other robots) I connected to the standard TCP / IP settings:
192.168.125.82
255,255,255,240
192.168.125.81
User: abb
Password: abb
In this case, it does not work.
Will someone help me with the TCP / IP connection if it is possible at all?
Photos:
Rating plate -> https://zapodaj.net/78e2053353627.jpg.html
Computer -> https://zapodaj.net/6a7036502dbf7.jpg.html
System Parameters -> https://zapodaj.net/b7ecd1fdfeca4.jpg.html
Thank you in advance for all comments.
