KRC2 system use CP5614 A2 for Profibus. On the cp5614 board green and yellow led flashing together (firmware problem). How change/replace firmware?
CP 5614 A2 Firmware update
Andy_rus -
January 18, 2019 at 3:07 PM -
CP5614A2 is not for all KRC2's. Used firmware related as system software and hardware version. Kuka using special firmware for VxWin.
You can found firmware files on C:\KRC\Roboter\Drivers folder. Old version cards using FW_5613.bin and new cards using FW5614A2.bin. There is no method for card firmware change.
pfbms.ini
[MASTER]
MASTER_USED=1
DATABASE_PATH=init/laser.ldb
FIRMWARE_PATH=drivers/FW_5613.bin ;You can change which firmware use for system software.
WATCHDOG_TIME=3
MAPPING_USED=1
MAPPING_PATH=init/
;DEACTIVATED_SLAVES= -
I know about working with this card. We installed 8 robots via profibus. Problem with card, another cards with this cabinet working ok. We put this card to another cabinet, problem remain.
On the cp5614 board green and yellow led flashing together (firmware problem). How change/replace firmware in the card? -
Hello, I have the same issue with Profibus, Both LED blinking , can someone advice me how to overcome this?
If I install the new driver , will it be ok?
How do I get that driver?
The robot I am working with is VKRC1 and for this we are using a new single sided Profibus CP5614 A2.
