Hopefully someone can shed some light on this for me:
i'm trying to load the following proc.cfg file converted from rw5 to rw6, but keep getting 'Cfg file contains errors'
I assume the syntax has changed from 5.0 to 6.0 - i did use the migration tool. I cant find any information in the technical reference manual - system parameters. Proc are not included.
PROC:CFG_1.0:6:0::
CONVEYOR:
-name "CNV1" -sensor_type "CAN" -use_sensor "CAN1" -adjustment_speed 400\
-min_dist 0 -max_dist 3000 -correction_vector_ramp_length 2
CONVEYOR_CAN_SENSOR:
-name "CAN1" -eio_unit_name "Qtrack1" -connected_signal "c1Connected"\
-position_signal "c1Position" -velocity_signal "c1Speed"\
-null_speed_signal "c1NullSpeed" -wait_wobj_signal "c1WaitWObj"\
-drop_wobj_signal "c1DropWObj" -data_timestamp "c1DTimestamp"\
-rem_all_pobj_signal "c1RemAllPObj" -rem_one_pobj_signal "c1Rem1PObj"\
-supervise_max_dist_off -newobj_strobe "c1NewObjStrobe"\
-encA_fault_signal "c1EncAFautlt" -dir_of_travel_signal "c1DirOfTravel"\
-force_job_signal "c1ForceJob" -count_to_enc_strobe "c1CntToEncStr"\
-pos_in_jobq_signal "c1PosInJobQ" -obj_in_queue_signal "c1ObjectsInQ"\
-count1_from_enc "c1CntFromEnc1" -count2_from_enc "c1CntFromEnc2"\
-count1_to_enc "c1CntToEnc1" -count2_to_enc "c1CntToEnc2"\
-scale_enc_puls "c1ScaleEncPuls"
