If you shift an object in any direction and know how much you moved it is the a way to shift the program by the certain amount of movement and have all your points still be accurate?
Shift program?
ORDEP81 -
January 17, 2019 at 4:19 PM -
12.37 PROGRAM SHIFT UTILITY
The program shift utility allows you to offset the positions of an entire teach pendant program or a
portion of a teach pendant program. This is an easy way to adjust a teach pendant program after a
fixture or the physical location of a robot has been changed
