Hi guys!
I'm newbie in Yaskawa Robots and I have an issue:
Is there any way to emulate/force/simulate the digital inputs or the signals sent by Ethernet/IP from PLC to the Robot?
Thanks.
Best Regards.
Hi guys!
Thanks.
Best Regards.
Hello
How can we do it?
do you want send signal from PLC to actual robot or Motosim?
please explain more , what do you need.
Hello
Actually, I need just to force the signal via Motosim.
For example: in ABB and Fanuc robots its possible to simulate the I/O signals in the emulators or in the robot, but in Yaskawa i'm not founding how to do and don't know if this is possible
In the I/O monitor screen you can check mark the external input signal. If you are using EG-VRC you can simultate the input as on the real controller.
