Hy, my Name is RUi and i'm stuck in a problem.when i set the OUTPUT #41 the adress that is been read is 30091 that comes i think from an optional I/O board that i cannot find inside the nx100 controller. I would like to know how do i set the OUTPUT 3004x and the input 2004x that are on the concurrent I/O
Sumarizing my problem is that i can see in the pendant the signal 30091 set to 1 but i cannot see where it is phisacally or i can connect inputs in the signal 2004x but then i dont know the Number #IN that is correspondent with that signal,Because if i select #41 the program does not recognize 2004x i think that is recognizing 2009x like the output 3009x that i mensioned earlier. Please can Simone help me. Thanks you.
