hello everybody
i work on a kuka krc1 in france but today i had a big problem
let me explain
in the morning I saved .src work program on the floppy disk to be able to write on these files with a computer.
when I put the files back on the kcp they stayed 5 minutes and then faded back as before
I guess this is because the files. dat was not also changed on the computer ??
It did not work
so I took the initial program and I edit it on the kcp by hand by correcting each time the errors with the publishers
unfortunately then I could not select the program to test but only to load
and then
I am asked to overwrite the file and nothing happens
I can not enter the program except for an edition
so I restarted the kuka several times and each time it's the same
I have everything re edit everything works 15 minutes and then nothing
I can only overwrite the files and no longer select ......
I do not know if I was clear but hey I would need a little help if someone has already encountered this type of problem
thank you a lot
