The robot has been calibrated, and the zero point is lost at zero. Can we calibrate the zero point by entering the configuration data?
Robot zero loss
硕江苏 -
November 21, 2018 at 4:24 AM -
What do you mean by:
... and the zero point is lost at zero.
The calibration marks don't line up.
The robot won't move to a point (zero)?
Have you changed a motor?
Is it a single axis - or several?
The robot has been calibratedFine calibration or rev counter update?
If a fine calibration has been done, you will probably need to re-enter calibration data(or re-load from backup). -
The term "Calibrate" is probably ABB's biggest mistake on the MMI / Pendant, because everyone wants their robot to be calibrated, right ?
Update revolution counters... sounds scary/complicated, better not do that.
