Exact path with constant speed
  • lionpeloux
  • November 7, 2018 at 4:01 PM
  • lionpeloux
    47
    KRC2, KSS5.6, KR5002MT
    I am struggling with this (very) simple programme :
    LIN P1
    	LIN_REL P2
    	CIRC_REL P3, P4
    	LIN_REL P5
    	LIN P1
    P1, P2, P3, P4, P5 define a rectangle with a rounded edge (P2, P3, P4). See the attached figure.
    I am not able to find a way to make the robot follow this path exactly so it does not mark a stop in P2 and P4 (LIN-CIRC junctions).
    I know I can use the same set of instruction with C_DIS ($ADVANCE >= 1) and the bigger $APO.CDIS is the smoother the trajectory will be.
    But to have a smooth trajectory I need a quite big $APO.CDIS (around 50mm for a = 250mm) which is not desirable in my case.
    I would like to follow the exact path between P1>P2>P3>P4>P5 at constant velocity, which is physically possible because of tangency between LIN and CIRC. Is that possible for the robot ?
    Even more simple, what if I have three points P1, P2, P3, aligned. Will the robot always mark a stop in P2 if I write the following program and dont use C_DIS ?
    LIN P1
    LIN P2 ; robot mark a stop ?
    LIN P3
    Images
      • 61.56 kB
      • 640 × 480
      • 31
    Files
    LIN_CIRC.jpg_thumb 20.05 kB – 164 Downloads
  • Fubini
    282
    1,903
    • November 7, 2018 at 6:37 PM
    You have to use blending $Apo.
    From a physical point of view
    Quote
    is not true. You need to be at least twice continuous differentiable to follow a path with constant velocity. The Lin has curvature zero and a circ has a constant nonzero curvature. Hence entering the circ results in a instantaneous acceleration jump. It's the same problem you would have with your car running on the highway at 200 kph and trying to instantaneously turn the steering wheel. You will crash. A robot can not cheat physics. Hence the acceleration difference in Lin and circ need to be transferred. Blending not only transfers velocities but also acceleration.
    Concerning your Second question. Even if the lins are perfectly aligned the robot will stop. The command that tells the robot controller to try not to stop ist the blending command. But if you program in this case c_vel blending the robot will not decelerate at the sections transistion. Here this is perfectly possible because there is no curvature difference.
    Fubini
    Edited once, last by Fubini (November 7, 2018 at 6:51 PM).
  • lionpeloux
    47
    • November 8, 2018 at 3:28 PM
    Oh gosh, you're right !
    Constant velocity on the circle means constant inward acceleration (perp to the path).
    But constant velocity on the line means null acceleration.
    So there is actually a jump in (perpendicular) acceleration at the tangency point and the only way to blend acceleration continuously while staying true to the path is to stop at the tangency point.
    What sort of blend is using the KRC ? Is this a kind of clothoid ?
    See : https://en.wikipedia.org/wiki/Track_transition_curve
    SkyeFire
    1,060
    9,456
    • November 8, 2018 at 5:32 PM
    The approximation is based on multiple factors. For a path from A to B to C to D, with B and C approximated, the path will begin approximating at a distance from B controlled by $APO, but limited to no more than 50% of the distance between points.
    This means that, if A and B are far apart, but B and C are closer, a "maximum" approximation at B will cause the TCP path to begin cutting the corner at 50% of the distance from A to B, and "get back on path" at 50% of the distance from B to C.
    The manuals cover this in detail.
    Basically, when Approximation is used, the programmed points act more like "attractors," within a specific rule set. If you need to run a path exactly through your set of points, you can look into Spline motion, which KSS 5.6 supports, but it can get tricky, and has its own tricks. For one thing, the "twice differentiable" that Fubini mentions still applies, and the "conversion" between "classic" motion and Spline motion can get a little tricky. You'll need some practice to get it right.
  • Brecht
    • July 28, 2023 at 5:32 PM
    Your explanation shows me why I'm working on something that isn't possible. I was following a course of Kuka (Robot Programming 1) : there was an exercise where a spline should follow a constant velocity.
    This exercise is mathematically not possible? Is my interpretation correct?
  • Fubini
    282
    1,903
    • July 28, 2023 at 5:50 PM
    Sure its possible. But you have to either use blending or better use a spline block. Since the rest of the task is about conditional stop and constant velocity the block is the intended solution anyway. In this case you need to add a spl segment between each scirc and the following slin and vice versa. Spl segment than takes care to meet the conditions on velocity and accelaration of its neighbouring points. The task does not forbid this.
    Fubini
