What is the most accurate and/or easiest way to set your TCP? Im have different weld torches and wire lengths so I have to keep readjusting and have a hard time of getting this setting accurate in Roboguide/WeldPro. I go to UTOOL tab then check Edit UTOOL then manually move the TCP to where i think it should be. I know this is not accurate but dont know any better.
Roboguide: TCP settings
ORDEP81 -
October 9, 2018 at 9:34 PM -
There an option to set tcp accurately in the roboguide using measuring tool. open measuring tool then select FROM and FACE CENTER as entity selection to find center point of the surface where you want to set tcp. click on the surface software will find center point then select some TO point. now there is an option Utool right down of the same screen. Open it and select From pt. so that your TCP will set accurately. this a better option try this.
