is it possible to declare and/or define a user frame and a tool frame inside a INFORM code?
User Frame yes with the MFRAME command. Tool frame no.
Tool frame if you have the PMT option to give you GETTOOL, SETTOOL instructions.
How do I use the MFRAME command? I am trying to use it into the inform code and check it in MotoSimEG, but I cannot change it...
How do I check this option?
If you have it, there are GETTOOL and SETTOOL instructions under ARITH in the INFORM LIST. The amount that SETTOOL can change tool data value is determined by a parameter. If the change is greater than the parameter allows, you'll get an error.
But be aware that when you change tool data, the trajectories of all the linear movements using that tool will change.
What Reintz said plus you will not have these instructions if you have the FSU on the controller.
How can I change the value of this parameter?
I have a doubt about the reference of this SETTOOL. Every modification that I do will be in the reference of the mountplate?
It is a paid software option.
