Hi kuka Roboter,
I am currently doing kuka olp in Robot master software for thermal spray application.
The total no of points will be 10000 plus.
I would like to understand by default how to give approximate positioning .
My program will have 10000 line of ptp and linear paths.
While running the program the robot should not stop and go in each points. Instead the program should of smooth flow of complex curves.
I need to declare a common variable for smooth path flow so that robot will not accurately stop at each points.
Any help would be highly appreciated.
Thank you
Bala
