Kuka robot approximate positioning default
  • Andrew149
  • September 18, 2018 at 12:29 PM
  • Andrew149
    35
    Hi kuka Roboter, :help:
    I am currently doing kuka olp in Robot master software for thermal spray application.
    The total no of points will be 10000 plus.
    I would like to understand by default how to give approximate positioning .
    My program will have 10000 line of ptp and linear paths.
    While running the program the robot should not stop and go in each points. Instead the program should of smooth flow of complex curves.
    I need to declare a common variable for smooth path flow so that robot will not accurately stop at each points.
    Any help would be highly appreciated.
    Thank you :merci:
    Bala
    All is well
  • nikhilpotdar15
    15
    • September 18, 2018 at 1:42 PM
    What I have observed is, when there is change in acceleration and approximation, robot tends to stop at that point and continue. If you want to have smooth motion without stopping but want to vary approximation or acceleration then you should always keep both acceleration and approximations in the ratio of 1:1. You will have smooth motion without stoppage.
  • Andrew149
    35
    • September 18, 2018 at 1:57 PM
    Thanks nikhil. Where to define C_DIS variable or where to check.
    All is well
  • SkyeFire
    1,060
    9,456
    • September 18, 2018 at 2:20 PM
    There are several options for doing this in KRL. The most advanced of which would be to use Spline motions, although I don't know if your OLP software can accommodate that.
    For "classic" PTP and LIN motions, you have multiple options, depending on what version of KSS your robot has. Most often, C_PTP for PTP motions, and C_DIS or C_VEL for LIN motions.
    C_whatever is not a variable, it is an option appended to a motion command, like so:
    LIN P1 C_DIS
    Without appending the C_ option, the robot will execute the motion command and decelerate to a full stop, before beginning the next motion command.
    The parameters of the approximation are defined by the variable $APO, which is a Structure variable containing multiple options for the C_PTP, C_DIS, and C_VEL.
    One thing to keep in mind is that no approximation takes place more than 50% of the distance between points, regardless of the settings in $APO, and the approximation between Point 1 and Point 2 can be affected by the distance between Point 2 and Point 3.
  • Andrew149
    35
    • September 18, 2018 at 2:24 PM
    Thank you very much.
    All is well
  • Shubham Jain
    33
    • October 11, 2019 at 9:35 AM
    Have you used these variables like c_dis or c_ptp ? Then please share the pictures and if we are using these variables then have to we need to make command of lin and ptp etc.
    SHUBHAM JAIN
