how do i clear it 0
how do i check the motion limits (0) 0%
where in tech pendant do i start (0) 0%
i am a professor trying to get our robot started so we can add roboics to our course, at florida technical
There is an error code lookup website in one of the sticky threads. Also highlight the error on the teach pendant alarm log and press shift+diag to see the instructions.
To answer your question directly, it is saying the position you are trying to move to is out of reach of the robot or beyond the limits. You may need to change the position, user frame, user tool, or axis limits to correct the situation.
Additional thought:
You need to also make sure the robot is mastered correctly. All witnesses marks should line up when each joint is at 0 degrees.
Hopefully you have the manuals; they will cover most alarm codes and other information to help you get started.
Which campus is going to be teaching robotics? I ask because I am in Winter Park. If you need specific help feel free to message me directly.
