Hi Guys,
I'm a paint and sealer guy and I just did my first M2000 handlingpro robot. I set up payload and DCS and everything looks good. When we run in auto the speeds and everything are okay.. We I got to teach and jog - the speeds are okay, however, when I try to step through a process the robot moves extremely slow like almost imperceptible. Safe speed is not on - I'm thinking it is something to do with my payload. Any ideas?
M2000 steps through program extremely slow
Presto -
August 19, 2018 at 5:24 PM -
Hi Guys,
I'm a paint and sealer guy and I just did my first M2000 handlingpro robot. I set up payload and DCS and everything looks good. When we run in auto the speeds and everything are okay.. We I got to teach and jog - the speeds are okay, however, when I try to step through a process the robot moves extremely slow like almost imperceptible. Safe speed is not on - I'm thinking it is something to do with my payload. Any ideas?Check the override do you use.
Enviado desde mi SM-G950F mediante Tapatalk
I'm not sure what you mean?
No estoy seguro que quiere decir?
Safe Speed should be ON
If the input is OFF then a safe speed limit is applied.Speed override is under SETUP menu
Two inputs are defined to control the playback speed
Both inputs should be ON to run the program at max allowable speedSent from my iPhone using Tapatalk
