Does anyone know the difference between a fine tag and a PL tag and is one more accurate than the other also does anyone know why some of our DX100 controllers have both a fine tag and PL tag and some of the controllers only have a PL tag selection???
Fine tag VS PL tag
BAlexander -
July 16, 2018 at 6:00 PM -
FINE=0 and PL=0 are the same. The FINE are pulse counts from the command position. PL are distance from the command position. The FINE is tighter than a factory PL=1. So if you need something tighter than 12.5mm use a FINE.
The parameter for FINE is S2C724=0.
ok great thanks for the response very helpful
Well I looked at the S2C724 variable it was set to 0 and still no FINE tag selection
It's S2C 722. It is probably set at 1, set it to 0 to enable FINE.
