do you know how to increase the TPP memory of my robot?
It is now 700 KB and i have available 141.
Can i make it 1700 KB?
Thank you in advance
I have read on this forum that this is an expensive option that you can purchase, that does not really increase memory that much. You may want to search the forum for prior posts.
You can always just save your programs onto A laptop, or memory card. This is what we do, You can then delete them off the robot memory to free up space.
Then you can just upload them back on when ever you want. It is good to have backups of all your programs saved somewhere other than your robot.
If all of your programs are saved only to your robot, you are only one power outage, or mistake on your teach pendant from losing them all.
To reallocate memory in a pallet tool job you have to go onto the software pcmia card for the robot and modify the ptlite.dat file with notepad. It is found in the /product/h552 directory. You will see something like this:
512 100
1024 100
2048 150
3072 250
Change the number corresponding to the amount of SRAM you have installed. i.e. 2MB you would change the number next to 2048. The number you put in will be the amount of TPP memory you will have.
Then do a full software install.
Actually, i use the .TP programs in order to save the parameters of the materials.
is there any way that i can use a PCMCIA card or usb memory in order to save and load the .TP programs at this?
thank you in advance.
You might want to replace your FROM/SRAM module to a bigger one (maximum is 3MB SRAM). If that still isn't enough, you might ask Fanuc for an option called TPDRAM, which allows you to store .TP programs in FROM and automatically loads them to DRAM on startup.
