start point equal to end point
  • furko
  • June 21, 2018 at 5:02 AM
  • furko
    hello to all!i dont know if this is the right group for help i need,but ill try,.i have problem with table spinning,every time when i start the program,i have error start point equal to end point,i dont know what cause this problem,yesterday i weld normaly,today problems,maybe orientation parameter is problem?i dont know what to do anymore,thanks for help
    Sent from my iPhone using Tapatalk
  • hermann
    412
    2,629
    • June 21, 2018 at 8:00 AM
    Problem is what the message says.It seems that you want to make a whole 360 degree circle in one line. This is not possible. You have to split the circle into two parts.
  • furko
    • June 21, 2018 at 8:56 AM
    yes i try alredy with more,2,3 circ lines ,but same thing hapens all the time
  • furko
    • June 21, 2018 at 8:58 AM
  • hermann
    412
    2,629
    • June 21, 2018 at 9:34 AM
    Attach the program files (.src and .dat). There must be something wrong with the coordinates.
  • furko
    • June 21, 2018 at 9:54 AM
    now i weld with the hand and not table spinning and its ok,but if i want weld only with table spinning,not working,not mathers,thanks for your time!
  • hermann
    412
    2,629
    • June 21, 2018 at 10:38 AM
    So the center of the welding is the center of the table? Then I think the table is not integrated properly into the transformation, or You use the wrong base.
    Now I see:
    If the screenshot of the program is correct, You really use the wrong base. You should use base 17, where the table should be integrated into the transformation.
  • furko
    • June 21, 2018 at 12:03 PM
    thank you,you were right,its 17,now everything works fine,thank you again,you save me
