Hi all,
There is any system signal to indicate to the PLC if I have made modifications in the robot programs.
Thanks.
Detect in PLC that a program was modified??
ctor -
June 6, 2018 at 8:17 AM -
Never heard of such a signal.
You can see the last modifications to the program on the teach pendant, date modified under detail when highlighted in select screen.
You can see the last modifications to the program on the teach pendant, date modified under detail when highlighted in select screen.But is it possible to send the date of the last modification to the PLC?? I need to detect with the PLC if someone have modified the programs in the robots. Maybe there is a system variable to detect if bgedit is on or something like this...
Thank you.
Never heard of such a variable, but maybe you can build something custom using KAREL and logbook.ls.
