Hi everyone!
help me solve the problem, please.
i have a event message 12008-Missing attribute is missing in cfg file
don't remember when it has appeared.
i add a pic with the message on flexpendant
Which configuration file shall i re-edit.
I watched EIO, MMC, MOC,PROC, SIO, SYS. There is nothing to change on line 63
Event message 12008-Irc5 compact
mr_ruslan -
May 25, 2018 at 7:42 AM -
A quick survey of the SYSPAR folder in a machine showed the -Act1 in the EIO.cfg file - more specifically, in the EIO_CROSS: section.
YMMVDo you have a backup file you can check?
yes, i have backup file
yes, i have backup fileThat's a good thing...
If you cannot find the differences by checking the files, you can probably* save the current config file under a different folder/name and reload the backup.
(*I have little experience w/ IRC5 and less w/ compact controller) -
thank you!
