Hi all,
The KRC2 is a BmW version, KSS 5.4.11, .
Using this X11 wiring: open attachment "1.jpg"
This robot has an 7th axis, it was disabled by changing $EXT_AX_NUM=1 to $EXT_AX_NUM=0.
I’m getting the following errors when as soon I tried to jog any axis:
Open attachment "2.jpg"
I have swapped RDW, ESC board and still get the same errors, please help.
KRC2 problem solving
c2c2 -
May 9, 2018 at 3:56 PM -
When do these errors occur? Whenever the robot is booted, or only when you attempt motion?
The chain of "PM1" and "KSD" errors suggests that you have a serious communication issue between the MFC card and the PM1 module.
Only when I attempt motion.
Will map other KRC2's wiring tomorrow or swap MFC and PM1.
The following question is for another BMW KR210:
When blue screen appears after entering KSS what could be the issue?Thanks,
Blue Screen Of Death (BSOD) usually suggests either software corruption (files on the hard drive), or a hardware issue in the PC rack.
Usually, the first thing to try is to re-install KSS. If that doesn't work, try re-installing Windows.
If that doesn't work, then it could be an issue on the motherboard (like bad capacitors), corrupted sectors on the hard drive, or RAM problems.
Thanks Sky.
yup is the mother board, spent more than 12 hours swapping C2 PC boxes and found 2 of the PC boxes out of 5 were not working.
Faulty MFC board can blow the fuse in DSE card, I had twice yesterday.thanks again.
Hi again,
Can I use Super370SBa to replace sy-7vba133-k? what do I have to look out for?thanks,
