Hi
I have Kawasaki robot with C controller. It’s display error ERROR (-1102) VME bus error.
please help me resolve!!! Thanks thanks
Hi
VME Bus error is usually related to problem on communication bus within the Card Rack assembly.
Also, a separate code is included with error too, but is not displayed on the Teach Pendant.
Does this occur during power up, or during normal running?
If you connect PC (KCWin32 - RS232) during bootup/normal running, you can see if VME Bus error occurs and contains additional code.
Historically I have seen this occur with faulty 1GA/1HA CPU board (Memory), but can be caused by any board connected in Card Rack File.
If 1GA/1HA requires replacing, then you will have to obtain TP, AS, SV Firmware and prepare 1GA/1HA and also have full Controller backup to return to operation.
You could try re-initialization:
** Make Sure you have Full file save before - if not, do not carry out **
1. Power Off Controller.
2. Set CPU Board Dipswitch SW1.......No 1 and No 8 to ON (the rest OFF).
3. Power On Controller
4. When asked to Initialize - Enter 1 for yes.
5. When asked are you sure - Enter 9894.
6. Set Memory Capacity - Enter 0 (Common is for 1Mb).
7. Controller will complete boot up with errors - ignore errors.
8. Use either PC, Floppy, PCMCIA to load in ALL data file save backup - Answer Yes, Force Entry to ALL questions.
9. After Complete, Turn Off Controller.
10. Set CPU Board Dipswitch SW1.......Turn Off No 8 and leave only No 1 On.
11. Power Controller On.
12. Usually have 2 errors - Joint abnormality (re-settable) and Check Sum Error (Not re-settable).
13. Reset Errors till only Check Sum Error exists.
14. Goto Aux Function 78 and select Clear Check Sum Error.
15. Reset Check Sum Error - Should be error free now.
16. Confirm robot motion and known locations and zeroing is correct by moving to all scribe lines and confirm 0 degrees for each joint.
17. Put back into operation and monitor for problems.
Check the communication bus within the Card Rack
