I use a KRC1 and I get the error "input buffer overflow" when reading data from a serial port.
I have searched the site and it is mentioned that a CREAD command clears the buffer.
I've read the manual but I can't find anything about this.
How is it possible to clear the buffer?
KRC1 - Clear serial input buffer?
Angelos Stathis -
April 30, 2018 at 3:14 PM -
normally simply reading data will remove it from the buffer. if the amount of data received can exceed buffer size in time it takes to read the buffer, consider using hardware handshaking
