Dear all,
Is there a way to show a message / pop-up on the teachpendant when executing a job instruction? If yes, which instruction should I use?
Thanks!
Dear all,
Thanks!
MSG will show the message on the message line. DIALOG will be a pop box displayed in the general display area.
With DIALOG Informal Instruction we can generally do a pop up. With String Variables we set names and with Byte Variables we set spacing.
IF your lazy You can use INPUT informal instruction.
Try you will come to know.
