I need to have the reset button of the TP to a DO in order to reset the other machine parts.
how i can do this?
Thank you in advance!!
how i can do this?
Assign UO signal to DO.
There is no UO output for the TP Reset button.
You can use the UO6"Fault" signal falling edge to reset the other parts.
This, however, will not work, if the robot itself was not in fault when the button was pressed.
Does it necessarily have to be the RESET button, or another button on TP is OK?
And do you have background logic available on the robot?
