Hello
I have a dc1 rectifier 3HAB8101-2 (DSQC 345B)
And I want to replace it with 3HAB8101-10 (DSQC358C) = DC2T ( with ext axis)
If I want to have an external axis is it ok for my tranformer to have one more axis and where to I should connect an extra smb? (Measurement system 2?)
Thank you!
Rectifier change
PaulSola -
March 8, 2018 at 11:53 PM -
Hello
Thank you!Hi,
If you would like only 7. axis, you don't necessary using SMB2. You can connect the axis 7 resolver cable to the robot SMB board. The SMB board can use 7 axis.
But if you would like use SMB2, this more complicated. What kind of type is the controller? S4C or S4C+? -
Thank you for your reply!
I have s4c controller (abb irb 2400 m98a) -
I think you meant smb 562 or smb 633
These do have one extra node for ext axis (6+1)
And as I know other have only 6 nodes for 6 resolversAnd now I am going to connect my smb2 to robot smb and use only measurement system 1 ( ext axis I will connect to 4rd node on smb2)
Do you have older smb? So I know all smb can use 7 axis.
I'm curious about the result. -
I have smb 313
I have smb 313You are right, the DSQC313 is different. You can connect smb2 to smb1.
I read the manual. (IRB2400 M98A Product Manual page 266 has a good figure)
