Hello, I`m trying to add a Murr I/O module to Kuka Agilus in WorkVisual.
1. I have updated DTM catalog (moved everything from left to right)
2. I imported Murr Gsdml file
3. I added profinet to Bus Structure and then Murr panel to PROFINET IO
My problem is that those IOs are not showing in the Mapping window. But when I`m adding any KUKA IO module, inside the ProfinetIO, the signals are ok.
I think it is because KUKA modules are comunicating via EtherCAT not Profinet. The other thing is that when I try to 'connect' Profinet under' Bus Structure' I get message 'No network adapter has been selectedPlease change the communication settings'
Edit1:
In my Profinet settings I have no options in the Network Adapter, only <undefined>
As this is my first post, I would like to greet eveyone from this forum, You are great help to others
