Thank you hermann. I wrote some OUTW to communicate with PLC but before i could test the program my kuka file didn't respond again. Tired of restoring the image and formatting HDD
The problem is my KRC program stop responding all of sudden sometime. Firstly I changed the HDD and restore new image, everything worked fine. But Again after few days the software didn't respond. I restarted the CPU and tried again and again but same problem occurred every time. then I format the HDD and restore the image backup. I did this process already so many time in this 2 week. may be the HDD are old? I have not tried into new HDD. I tried into 3 OLD HDD that I have.
Today again my program stop responding when i tried to reset the profibus and when I started once it showed me error saying "101 DSE 1 boot up failure". but later when I restart the CPU it startup and end up with not responding window as shown in attachment. Then once it is like that no matter how much time u restart it will end up starting KRC program like that.
Is it that there is some file missing or corrupted?
Does any one have any idea why do i get this error frequently? may be my image is not good? or may be i keep on using old HDD just formatting? or may be some other problem?
I need really good suggestion to fix my cpu so that i can work on programming ....
Thank you
