we have a Fanuc 710i material handling robot with the RJ3IB controller that I am trying to get operational. I had it running about 6 months ago and the project was canceled. we put the 710i back in storage. now, there is a new project and trying to get it running again. but I get a "prio-020 common error 83,81,0 a communication error. I have checked all of the cable connections but I can not get ride of the error. I am new to robots and need some advise
PROIO-020 I/O link common error 83,81, 0
Dean -
February 12, 2018 at 6:57 PM -
do you have 24v connected to the devicenet card to the red and black
where is the card located
See attachment
thank you for taking the time to help. this must be older. I only have two vertical gray towers and they seam to be light up. I see green lights here and there. I did check the two green fuses with a meter.
Post a pic
Bro, I fought this problem for a long time. My issue was a bad communication cable between the robot i/o modules. Apparently, the communication cable was drooping down far that it was shorting out on another terminal. I would go and move around the cables and it would magically start working, and then after an hour or two I would get the same fault; all because the cable drooped down and hit the terminal.
Double check the main controller, if there are no errors on it, then it's definitely somewhere in your I/O chain. Make sure everything is grounded properly and make sure all your cables are secure and not drooping down like mine were. I was using BMD88A1 digital i/o cards.
Make sure you have the terminating resistor enabled on the last I/o module also and the very first one as well. Should be labeled "R" on the dip switch.
Let me know how this goes for you.
